Will Van
GOLD Star
- Thread starter
- #241
Make sure you use some fuel resistant sealer on the threads & under the bolt heads of the flange bolts. The one time I had a leak from the bolts, was when I didn’t use anything.
I’ve been using the Permatex Aviation Sealant with good luck.
Thanks for the tip! This sounds like a much less expensive option than replacing the whole unit. At least worth a shot before replacing with a Holley setup.
