I installed a new radio and have been having issues with speakers cutting out when engine is above idle speed. I checked the the voltage on the battery and all is good at 12.5 with engine off I then started engine and tested voltage which came in at 17.4. As suspected the voltage increased above normal. It appears that radio shuts off output at higher voltage. I believe the output from alternator is too high causing radio to stop normal output. The head unit never shuts off it just shuts down sound. Has anyone experienced this? Is there a way to adjust voltage regulator? Is regulator bad? Do I have another issue I have not thought about? Is it the alternator. Any help is greatly appreciated
