- Thread starter
- #781
looking really good...
Thanks!
I have 7.5 and it is perfect with 37" tires. 95 mph and hands off steering wheel, although that was a one time deal. It drives great. I would shoot for 6 min, but your call.It is set at about 6°, I may go up to 7°. I'm thinking the same thing with the panhard. The upper mount is being a massive pain to get it to clear the axle, tierod, and upper link mount. If I only had another inch....
There's some flexible sections of that fuel line correct?Sniper fuel lines bent.
Rear tail lights wired up.
Dash almost finished.
Looking great man!
Have you tested your rear driveshaft at full droop?
Your fuel tank is inspiring! It looks great. Do you still have a sump and/or baffles for the pick-up? What are you using for a fuel-pump and pick-up?
I have an external high pressure fuel pump (Bosch 044) mounted on the bottom of the floor behind the t-case and its loud. but I was hesitant to have the in-tank pump plumbed in the cab as a leak with 60PSI fuel could be pretty exciting for the occupants.
Excellent.
Definitely.You wanna go on some highway runs to break stuff in? I'm not sure if I want to go alone, yet.
Front calipers cleaned up and painted.
I built my brake system and it is bled 100%, so this thing is about ready to run.
Rear light housings installed.
The LEDs look great. Big shoutout to @SandiaFJ40 for an awesome product.
Rear wiring plug made, and wiring cleaned up.
I filled my axles, transmission, toybox, and transfer case with
The lights look great! Well done on the install. Those should hopefully brighten things up for ya!
