Good to catch up and thanks for the 80 stuff!Horns installed.
The dakoda digital is all wired up now. It looks great.
@cbmontgo stopped by to pull some 80 parts. It was good to see the 47, Carson!
Turning out great...
Beautiful. I love rebuilding knuckles. I think FJ 80 axles are the way to go. I wish I had done that. But when I built my 40 that was not being done. People were putting Dana 60 in and I wanted to stay all Toyota DNA. You are doing a great job DJ
°°Looks like your going to have to use a bent Panhard bar similar to what a stock 80 series uses on the front. Tie rod should he fine. Do you have your caster set?
In my opinion 6 or 7 is a bit excessive. I would aim for more like 3 or 4, maybe even 5. Having a lot of caster will build a lot of heat in the power steering fluid at low speeds. That would also give you more tie rod clearance if it was around 3 or 4.It is set at about 6°, I may go up to 7°. I'm thinking the same thing with the panhard. The upper mount is being a massive pain to get it to clear the axle, tierod, and upper link mount. If I only had another inch....
It would just give you more tie rod clearance at the frame if that's a issue.Good to know. I've always heard that the bigger tires really like a lot of caster to keep them more driveable. I'm not seeing how it would give me more tie rod clearance to the diff, wouldn't it stay in the same spot?
