Last week, it was running fine, and would start right up.
Over the past several months, every once in a while (and now every time), it does nothing when I turn the key. I could come back in the evening and it would crank like normal.
These days, it's a no go.
The ONLY thing that happens when I turn the key is that the ammeter drops.
So far, I've changed/tested these things.
Any other ideas?
- Replaced battery
- Replaced starter & solenoid (non OEM)
- Checked continuity from starter to ignition switch
- Replaced ignition switch (OEM)
- Removed fuse block and clean all terminals
- Checked fuses
- Removed and cleaned main body ground
- Fusible link is good
Any other ideas?
