Thanks for the reply. The cylinders ended up being a little rusty and stuck from sitting. Was not the clutch or flywheel assembly at all.I have mine (6/76) FJ40 apart right now for complete drivetrain rebuild. Nothing between the flywheel and the crank (spacer, etc.) that I recall. Bellhousing bolts to the block in between of course. Are you rubbing the block? Can you get a pic?
