- Thread starter
- #501
The most important part right now is the concentricity. How is the fit on the output shaft? And the input of the ToyBox? A weep hole will help keep the spline wear down.
Mike
They don't fit super tight, which is why I believe the bearing exists. Normally, the shaft is bolted through the input gear of the t-case, and they still have the bearing, so I assume that it probably would need it.
I'm not sure how well the splines fit into the toybox, but it should be a good fit. I would need to trim the shaft to see that.
