1975 FJ55 Clutch Master leaking (1 Viewer)
Clarksville, Tennessee
Website
hotmilkforbreakfast.wordpress.com
I've been spending the last month piddling around, slowly fixing a burnt exhaust valve.
Just as I get it running today, I discover this:
img_20211105_164152901-jpg.2830837
Are. You. Kidding. Me.
The clutch master has started leaking out the back, literally overnight.
So, I have found what I "think" is the correct replacement here:
https://www.sor.com/CAT018.sor?TABPAGE=TAB1#
Part # 018-01D
I am wondering if a) this is the right part/best solution, b) what are the chances that the bottom cylinder also needs replaced, and c) is there a kit available where I replace the whole shebang?
Thanks!
I would see if cityracer has it, likely cheaper and better shipping. Not a bad idea to replace the slave cylinder at the same time. Maybe the hose while you’re in there.
X2 on replacing all the above parts, master, slave and hose
I did a Google search and found Aisin brand master and slave cylinders at Partsgeek, and an FJ55 specific hose which is a repro. I've never done business with them before, but figure $100 is worth taking the chance.
Part #W0133-1624463
I don't know if FJ40 and FJ55 hoses are different, but I'm a sucker when a parts source lists "FJ55" as an option.
I ordered mine from rock auto. All aisin stuff except the hose was a "centric". There's a discount code to use in the vendors section. It was also for a 1975 fj55.
