1975 FJ55 Clutch Master leaking
  • Thread starter 120mm
  • Start date
  • Watchers 4
120mm
120mm
Clarksville, Tennessee
Website
hotmilkforbreakfast.wordpress.com
I've been spending the last month piddling around, slowly fixing a burnt exhaust valve.
Just as I get it running today, I discover this:
img_20211105_164152901-jpg.2830837
Are. You. Kidding. Me.
The clutch master has started leaking out the back, literally overnight.
So, I have found what I "think" is the correct replacement here:
https://www.sor.com/CAT018.sor?TABPAGE=TAB1#
Part # 018-01D
I am wondering if a) this is the right part/best solution, b) what are the chances that the bottom cylinder also needs replaced, and c) is there a kit available where I replace the whole shebang?
Thanks!
Skreddy
Skreddy
Stanwood, WA
I would see if cityracer has it, likely cheaper and better shipping. Not a bad idea to replace the slave cylinder at the same time. Maybe the hose while you’re in there.
scrapdaddy
scrapdaddy
Standing on the corner
Dittmer, Mo.
scrapdaddy
scrapdaddy
Dittmer, Mo.
Seems to be out of stock right now.
120mm
120mm
Website
I did a Google search and found Aisin brand master and slave cylinders at Partsgeek, and an FJ55 specific hose which is a repro. I've never done business with them before, but figure $100 is worth taking the chance.
Part #W0133-1624463
I don't know if FJ40 and FJ55 hoses are different, but I'm a sucker when a parts source lists "FJ55" as an option.
KingAir Driver
KingAir Driver
Spokane, WA
Good info. Looked at mine last week and it was empty. Disappearing fluid after sitting for 2 years. Ugh.
derail
derail
Redding,Ca.
I ordered mine from rock auto. All aisin stuff except the hose was a "centric". There's a discount code to use in the vendors section. It was also for a 1975 fj55.
Similar threads
GUGISMAN
Replies
2
Views
93
65swb45
PRETRD
Replies
8
Views
264
greenbeast
pbgbottle
Replies
10
Views
256
Downey
Downey
