1975 fj40 wiring
Colorado
Attempting to re-wire heater switch. Pulled switch from 1974 Fj40. It has 4 spade male plug, female half missing. Connected Blue wire/Red stripe to same on male. I have power. I have Blue with black stripe and Blue with White coming from blower. No matter which way these are switched only can get high speed and off nothing from low. Is there another colored wire missing from PO as i can only find 3 wires newby to site post. Have read a lot of great posts from past for info. Please help if you can thanks.
Engineer8000
CAPE FEAR ELECTRONICS
SOUTHPORT NC
Website
forum.ih8mud.com
Based on schematic, LB is Hi and LW is low.
ToyotaMatt
Factory Focus-Point Mind-Set Approach
Supporting Vendor
GOLD Star
EAST COAST
Website
vintageteqparts.com
your 2 L or BLUE w / black tracer stripes are both the OUT GOING Travelers ...........................fyi
hi and low
- since this is your First TECH. RODEO , we are going to CEMENT the T-TEN factory focus points mindset approach philosophy and skool of period correct JDM thought process here from the get go right away without delay ......
- below is the TOOLS you need to introduce yourself to , get familiar with , then obtain your own paper print media copy , not some silly circus clown PDF to be clear here ...
- take a bit to review this and then report back here with the , if any questions you will have ...
- remember , the only dumb question is the one you don't ask ...........
hope this helps ,
and YES confirm the whole resister topic in the diagrams below ?
do u have one and if so is it good or burned up or simply missing ?
