1975 FJ40 Voltage Regulator Location? (1 Viewer)
New York
Any suggestions regarding where to look for the voltage regulator on a 4/75 FJ40?
I'm not getting any power from my alternator, and am pretty certain it does not contain an internal regulator.
Photo attached--the box on the upper left is the speed sensor maintenance detector, the wiring harness plug is disconnected from the alternator, and there is a battery tender sitting on top of the battery. I have followed the harness all the way back to the fire wall just under the speed sensor, and am curious if they ever put the VR inside the passenger compartment. I don't see it under the dash, and before I start pulling it apart, I'd appreciate any suggestions.
Thank you!
New York
Thank you!
Adding a few more photos:
Shark56
Dover, DE
That is the solid state version. They are pretty much impossible to find now for some reason. Two places, one Ebay and one on Amazon had a Solid State version for sale with pics and a part number. Both came as the original style, ( Non Solid State), in a box with the correct part number. From the research I have done that is a common occurence. Either will work. Several Mud vendors were selling the Original style.
Pacific NW
Speaking of voltage regs... I am in process of re-doing the whole wire harness. My brother thinks we should change out the VR and do an alternator with internal VR. Pros and cons? '76 FJ40
