I know this subject has been talked about millions of times and I've been reading, researching, and testing all the theories I've found on here so forgive the redundancy here....but I have been fighting this aggravating s*** for over 6 months now and I'm almost ready to set this bitch on fire and roll it down a hill!!!
WHAT I'VE DONE:
- the OEM tail lights were trashed so I had to replace them.
- I used some LED tail/brake lights from Etrailer to replace them
- Replaced the switch on the column with a new one from Cruiserparts.net thinking that was the problem
- Then I realized the LED lights would mess up the original flasher so I bought installed the one from CCOT
- I've checked and replaced all the fuses
THE PROBLEM:
- Turn signals WILL NOT WORK
- Front Hazard flashers will flash.....kinda fast
- Headlights work....dimmer switch on new turn signal switch works too
- Brake lights work
- Parking lights work
THE OTHER PART OF THIS CLUSTERF*CK:
- The P.O.......bastard .....cut in wiring, bypassed all kinds of s***, and was obviously completely opposed to using a butt connector!!!
- I don't know if this has anything to do with this but the Wipers DO NOT WORK either. I've checked the switch, plugs, and everything seems to be OK
Here's some pics of what I have going on here
WHAT I'VE DONE:
THE PROBLEM:
- Brake lights work
