1974 FJ40 Parking Brake Drum to U Joint Washer & Nut
Chicago, IL
I've searched high and low for the Toyota Part Numbers for the Nut and Washer that go with the Studs from the Parking Brake Drum (Part Number 90114-11124). Anybody happen to know what they are? Nut and washer for number 16 in the image for reference. Any help would be much appreciated. Thanks.
Liberty, Kentucky
Liberty, Kentucky
He said 74 so the numbers I provided are post 01/74. The links provided indicate this difference and have part numbers for both on the same diagram. I'm not sure what's in the image of the Cruiser TEQ part but the OEM hex nut is not flanged and the OEM washer is a wave or spring washer, not a flat washer.
Chicago, IL
Thank you all for your input. It is an 11mm.
I don't prefer SOR diagrams either it was just the one I had in front of me at the time and other official one wan't giving any better info.
here
Now be aware the 11mm nuts have different O.D., meaning they have diiferent size wrench depending on manufacturer. OEM are the best IMO.
