I have a 1974 fj40
Trying to put a throttle cable from the gas pedal to the Holley Carb. Previous owner got creative and did a hard wire linkage from the carb to a modified pedal. Just trying to get it running and on the road before I make any changes to the carb etc.
This is what I understand so far.
-----I need to modify a 1974 or new gas pedal similar to how project wrong way did his. Basically weld a rod to the gas pedal for the throttle linkage to hook to.
-----Drill a hole in the firewall for the linkage bracket (see picture below). It looks like I have the bolts in my firewall but there is no hole for the cable.
(picture from forum).
------I would also need to modify the top of the gas pedal to look similar to the older fj40 gas pedals to hold the cable. Or get an after market throttle cable?
------I would then run the stock fj40 cable from the pedal to the holley. And then modify cable to hook up with the holley.
This video I kind of similar to what I was thinking but I have a different pedal design.
Am I missing anything?
