1974 FJ40 crankcase pressure/oil leaks (1 Viewer)
Russell Springs, KY
I have a 1974 fj40 with f155 stock motor that has a lot of crankcase pressure and recently had side over, oil pan gasket and valve cover gasket leaks. These leaks have not all occurred at once, but once I fix one issue, drive several miles another ones happens. Is there someone with experience that could help me determine what would cause these issue ? I appreciate any help anyone could give me. Thanks in advance,
Tom
I just faced this with my '68 F. Two pistons had broken compression rings, even some pieces missing!!
A compression check will reveal much.
Is your PCV valve in good working order?
Check PCV valve first. Cheaper and easier to do.
Start the engine and remove the oil filler cap. If there is a wind coming out, you have a lot of blowby and internal engine wear. Also check PCV as mentioned.
