I made another thread regarding the starting issues.
The PO couldn’t work on it any longer due to a bad back. He intended to sell last year, but apparently friend poured ethanol in the carb, which eventually started a fire in the carb. So he decided not to sell until the carb issue was fixed. He sold it to me for a much lesser price than originally thought, while was still running.
here’s the immediate issue. The carb is cracked. will it affect the A:F mixture with a crack this high? Should I repair it? I’ve heard of the red permatex method...
i sprayed the carb filled with carb cleaner, and was able to get it running —only for the length of time to burn up the carb cleaner. So it looked like I wasn’t getting fuel to the carb. Im already making a list in my head - carb rebuild kit, fuel pump.I looked around the carb and noticed two things: the fuel IN line was wet (this may need to be replaced). Second thing: there fresh clean oil sitting between the valve cover and the carb. So I’m thinking gasket? Breather? Some of the oil was On the carb itself. Splatter? No idea.
Time has been limited since the car came home but so I’m glad I stumbled on ih8mud! Those are my current issues starting off with my new toy. I’ve already got a carb repair kit, air intake gaskets for the filter, and maybe a valve cover gasket coming too.
Am I in the right direction? What else should I look into after receiving it? Spark plugs? Any other gaskets to be replaced? I’m very green with working with carburetors or any old motor so help is appreciated.
