SOLD 1972 through early 74 - Toyota Medium Vinyl Tool Roll with Toyota vintage tools
on the trail...
Here's an original Toyota Motor vinyl tool roll with vintage Toyota tools. This kit was supplied with FJ40 and FJ55 Land Cruisers from 1972 through early model-year 1974. Detailed descriptions and photos follow.
full
This original kit includes the following pieces:
  • Spark plug wrench (20.6mm), 4-hole, marked Toyota Motor with Made In Japan below, with bar handle
  • Screwdriver (75mm), wood handle, flat blade, marked Toyota Motor on the ferrule
  • Screwdriver (100mm), wood handle, No. 2 cross-head, marked Toyota Motor on the ferrule
  • Screwdriver (150mm), wood handle, flat blade, marked Toyota Motor on the ferrule
  • Open-end wrench (8x10mm), recessed handle, marked Toyota Motor and Nickel Chrome Vanadium
  • Open-end wrench (10x12mm), recessed handle, marked Toyota Motor and Nickel Chrome Vanadium
  • Open-end wrench (12x14mm), recessed handle, marked Toyota Motor and Nickel Chrome Vanadium
  • Open-end wrench (14x17mm), recessed handle, marked Toyota Motor and Nickel Chrome Vanadium
  • Open-end wrench (19x22mm), recessed handle, marked Toyota Motor and Nickel Chrome Vanadium
  • Blue wrench clip (5-wrench set), with KTC M.PAT mark
  • Adjustable wrench (250mm), marked Toyota Motor
  • Pliers (200mm), marked Toyota, with KTC PAT mark
  • Lug wrench (21mm), 1-piece, marked Toyota Motor and Made In Japan
  • Grease pump, marked Toyota Motor and Made In Japan, with straight nozzle and curved nozzle with chuck
  • Medium vinyl tool roll, with full length strap, and chrome slide buckle, marked with TEQ logo and Toyota Motor Made In Japan
Tools are in very good condition and appear unused or lightly used. Tool roll has a couple small holes and stains and wear from age and use. There appears to be very fine over-spray droplets on the left side of the inner vinyl.
More images here.
full
full
full
full
full
full
full
full
This type of tool kit was featured in the 1973 Toyota Land Cruiser brochure.
wngrog
Moderator
Canton, Mississippi
Website
www.seeandeatms.com
Delete…you seems to have researched this. Carry on. I purchased one last week same vintage. Same price but not quite as nice as this set. Nice work.
If you have an extra long Phillips my kit is missing that
on the trail...
74 did not have this but 71-9/73 did.
Tool Box under the seat years
I thought that as well. But found a few early model-year 74s that claimed to have this kit as original equipment. These were Oct/Nov 73 build dates. So perhaps Toyota was using up the older tool roll kits before switching to the tool bags. Or maybe the tool kit change was done Feb 74 (mid-year for a normal model year). Later 74 builds all seem to have the dark green tool bag instead.
Interesting that the 73 Owner's Manual has a diagram of the kit and lists each tool. But the 74 manual does not have a similar diagram or list of tools. Like the manual writers knew the kit was changing. But rather than list details of one or the other and be wrong for part of the time, they decided to omit the tool kit details altogether. The 74 manual does include a drawing of a tool roll secured by 2 straps under the seat, while the 75 manual shows a tool bag held by 1 strap.
Thanks for the comment. I'm updating the ad to reflect that this kit appeared only in early 74 models.
