bobm
WTF, WTF, WTF!!!!
Nice, 3/4 ton Piggy . PG when that happen . Whats the story on COE in 1st pic?? Ford or Intermational??
Yes, his other hobby was restoring COEs. Don't recall what it was as that's the only picture I hadNice, 3/4 ton Piggy . PG when that happen . Whats the story on COE in 1st pic?? Ford or Intermational??
I'll run just a regular cone filter at first. I'm going to stick a second battery under the hood, so will wait to figure that out before I build a custom airbox. Ultimately thinking I'll build something that uses a stock GM truck filterNice find Steve. Love the direction and vision. Hope to see this one at SAS 7. What are your plans for an airbox? Running a factory unit?
No, he was just a flake. Some blah blah bs about his truck breaking down. Idiot didn't realize that since I paid him with Venmo I could see all his transactions. He just was an a-hole.Do you think the transporter was going to try to keep your Pig? I wonder if they were smitten by the Pig and thought maybe they could elude you?
The theme I am sensing is that a good network of friends is priceless. It can really get you through some challenges!
Here is the style I use linky. I've put them in several trucks. You need to run a DD converter or non-stock fuel gauge. I'm going to run a set of Speedhut gauges so I'll have no issue connecting it directly - temporarily I'll put an underdash fuel gauge I have laying around in.Floatless sending unit sounds pretty cool! What make/model are you going with?
So the back might sit a little lower once the tank is full, eh?Here is the style I use linky. I've put them in several trucks. You need to run a DD converter or non-stock fuel gauge. I'm going to run a set of Speedhut gauges so I'll have no issue connecting it directly - temporarily I'll put an underdash fuel gauge I have laying around in.
Yes, the body sit's level. It has about a 1-1 1/2 inch body lift. The back is just a bit higher as there's no weight there in those photos
50 gallons of fuel will do thatSo the back might sit a little lower once the tank is full, eh?
This was difficult to factor in with the slider shackle set up. Hamilton should be good once everything is installed ready to play.So the back might sit a little lower once the tank is full, eh?
Not even close. The 1 ton axles are wide. Later on I may narrow them but for now they stay. The flares aren't my favorite, but will decide on keeping them or not after I get it rollingWill these wheels tuck the tires better so you can get rid of those unfortunate 'flares'?
About to do some spraying of lizard skin. How much did you order to get the necessary coverage?
