Got a question for some of you more experienced cruiser heads out there. Here goes... Around 3 years ago the clutch fork in my '72 40 failed by bending in half. After tearing into the repair and inspection of the clutch, I decided to go ahead and replace the clutch / pressure plate assembly and throw-out bearing of which there was hardly anything left of. I also had the flywheel machined and replaced the pivot ball and installed a new clutch fork and slave cylinder. While I had the trans out, i replaced the leaking front seal and made a new gasket for the front bearing retainer. After reinstalling everything I was amazed at how much more quiet the rig was and didn't realize how bad my throw-out bearing was. After driving the cruiser for a few days i noticed it would develop a whining or squealing noise after about 10 minutes of running. It developed the noise whether idling stationary or driving. I imagined at first it must be a bad throwout bearing so I replaced it again with a new one but it didn't help the problem. The noise still came back. Anyone have any suggestions? I'm leaning towards a bad front bearing in the trans since it is a constant noise that fluctuates with RPM. Could it be a possible clutch adjustment / clutch slave cylinder adjustment with the throw-out bearing not letting it disengage? Any input would be appreciated! I haven't driven or worked on the cruiser in years due to other commitments (work, school, marriage etc...) but I'm finally at a point in my life where I've freed up some time and want to get dirty again! Thanks!
Eric TLCA #13472
1972 FJ40 (resurrected soon!)
1982 FJ60
1967 SS350 camaro
1969 Base 307 camaro
Eric TLCA #13472
1982 FJ60
1967 SS350 camaro
