Hi, when I push the brake pedal both turn signal dash lights come on but the brake lights do not. The tail lights work and both rear turn signal flashers work and the lights flash when the hazards are pulled on. I’ve tested the bulbs and they are ok. The wiring from the firewall back is all new from
Coolerman and has power and good grounds since everything else works as it should.
It looks like from older threads that grounds can be a problem but I have a really good ground for the harness and at each combo light, plus the turn signal flashers and taillights work. I am stumped and would appreciate any thoughts? Seems like since the dash lights come on that has something to do with it? I also noticed that when the tail lights are on and the brake pedal is depressed the bulb dims for a second right when the brake is depressed? Thanks.
