The engine starts and runs well, but when I disconnect the coil, it keeps on runnin…
Thoughts please
Thoughts please
^This x2Use your Google-fu to research ALL the causes of dieseling. Your proposed actions won't resolve the issue.
Hint: start with timing...
So it does the same thing if you just turn the engine off with the ignition key?You’re right, my initial description was vague.
This is a project truck that I’ve just acquired and never driven.
The run on is not smooth, sputtering and struggling… very much dieseling symptoms.
It idles at 600 RPM.
Ignition timing can’t be an issue because I’m disconnecting the hot side of the coil, there’s no spark at all.
Well, actually that's exactly why it's called 'dieseling'.Ignition timing can’t be an issue because I’m disconnecting the hot side of the coil, there’s no spark at all.
This statement is completely inaccurate. The term dieseling refers to the fact a diesel runs with no spark whatsoever, which is exactly what you have taking place.You’re right, my initial description was vague.
Too muchWhat's the main timing culprit wrt dieseling, too much advance or too little?
