Hi Guys,
I've had a long time problem with my 40 (original F engine and carb) since I bought it, where it stumbles and will stall (or nearly stall) when the throttle is increased coming out of idle (the harder the throttle is pushed the more it stalls). Everything else seems to work well (idles well, never stumbles once out of idle). I rebuilt the carburetor a while ago, but when I got it all back together the problem still existed (maybe a little better but still there). The workaround has always been to lightly double tap the gas pedal before trying to get the revs up since that gets the engine rpms up without it completely stalling, but I would like to finally fix the problem.
Today I checked with a couple vacuum hoses disconnected and plugged (brake booster and transfer case), but the problem was still there. I also took some video of the carburetor operating during that phase where it stumbles. I have posted a link here (stumbles occur at 00:17 and 00:23). fj40 stumbling
There is definitely gas being squirted in from the accelerator pump, but after that the engine will bog down unless more gas is pumped in (by tapping the pedal multiple times to get more from the accelerator pump). Eventually if the throttle is held down long enough gas starts coming out of the main nozzle (video doesn't capture that) and that allows the rpms to start to increase. So it seems to me there is a point where the mixture is getting too lean and causing the stall (or near stall). My question is whether there should be more fuel coming out of the accelerator pump or the fuel should be coming out of the main nozzle sooner (or maybe something completely different)? Thanks for any advice!
