It runs down the passenger frame rail.From the brake line schematic it does look like the rear break line does run down the middle of the LC.
Great! Thanks so much for all your help!It runs down the passenger frame rail.
This one also has the 3 on the tree. I got the break line off and it had a pinhole in it. It is the number 44 break line. Land Cruiser Brake Lines & Hoses 1958-1984 FJ40 & FJ55 - https://www.sor.com/cat086.sor#086A3 I just need to order the 10mm flare nut size line. I am assuming I need to order the break line made for a 3/70-7/70 FJ40. Thanks for your help! Much appreciated!I'm on my third FJ40 build project out of owing 4 FJ40's. The FJ40 in my personal shop now is a 1970 early model. Yes you are correct in saying "That is it! Thanks! So I need to replace the vac lines and then find the leak to the back brakes." I also have a 2F installed but using the 3 on the tree 3 speed transmission. I would be glad to help as needed. Ty Ps: At some point I need to get to a duel master and 10mm lines. Your a head of the game on the brakes....
