Hi all, I'm looking to tap the wisdom of the almighty forum.
Truck is a bit of a frankentruck as I got in over my head with rust and just went for it: frame swap from a '73 I think, Aqualu tub/cowl/windshield, but basically bone stock 1970 1F drivetrain down to column shift. In getting it back on the road it got a JimC carb rebuild, new fuel tank, new filters, new fuel line, new plugs, new radiator, new t-stat, and tons of other probably less relevant things.
For the last two summers it's been running like a top. Maybe a bit on the rich side, but super reliable. Turn the key and go.
Near the end of last summer on a zip around town as I pulled through an intersection it stumbled like the key was switched off for a moment and then caught again and took off no problem. Over the course of the day it got worse and worse with the same symptom. Intermittently cutting out. Didn't matter if I was accelerating or steady throttle. Ended up towing it the last few blocks to get home. When I tried to start it she'd crank over and sometimes splutter a little bit but won't stay running at all. Same situation today (somehow, letting it sit in the garage didn't magically fix the problem).
Carb sight has fuel in the middle of the window. Idle solenoid clicks when key is turned on. Gets 12v to coil with key on. Jumper from battery + to coil + makes no difference. Compression is good. Maybe high? Like I'm getting readings above 150 psi.
I'm not sure where to go next. Any ideas? Thanks in advance for the help!
