1968 fj40 transmission question
Content may include affiliate links. Please see terms for details.
orlando, florida
Need a little guidance. I have a 68 fj40, original with small lift kit. Aftermarket seats, no roll bar.
It has a 3 speed original that was converted to floor shift. Paint/body work done. My question.. mechanic that’s doing brakes has a 4 speed from a 78 FJ. The cruiser is just a toy to me, not a daily driver. Question: Do I improve my situation by installing 4 speed? Drive shaft change etc? How bad a swap are we talking?
Thanks in advance.
Texas
You will need:
4 speed bellhousing and inspection cover
Either new 4 speed drive shafts or modify your current ones by changing their length.
If you go with 4 speed drive shafts, you will need to buy pinion flange adapters. If you modify your 3 speed ones, you won't have to.
You can make it fit but people recommend to cut to torque tube and push it back a few inches so the transmission and t-case have enough room to work on
4-speed skid plate or modify your current one
You can keep your current 3-speed transfer case. It is "recommended" since this will give you lower gearing.
If you keep the 3 speed transfer case, you need a 74 or 75 transition gear to mate up to the 4 speed.
Keep your 3 speed clutch and flywheel.
You might need to make the hole in your transmission hump a bit larger.
4-speed transmission top cover with shift cane.
That's it from what I can remember.
Helena MT
the 4 speed will make daily driving easier/smoother
you don't gain top speed
it is your choice, but there are still lots of us running 3 speeds
Dynosoar
Slightly Disturbed
SoCal
3 speed - 3rd gear 1:1
4 speed - 4th gear 1:1
3 speed non synchro 1st :(
4 speed fully synchronized
Dyno
brooklyn
I would say a lot of work for little gain - now if you were swapping a complete engine, transmission, and transfer case from a late model FJ60 — I would say you’re getting some real benefits.
