Stock engine setup, connections should be good-battery 1 year old. Will check the voltage later todayIs this in a stock engine setup? How are the electrical connections? Grounds are all good? The lights definitely dimmerf at idle vs higher RPMs but I am wondering if your lights are not as bright as they could be to begin with? Are you getting 14v at idle at the battery? How old is the battery?
UnsureDoes the new alternator have a smaller pulley than the previous one?
Lighting dramatically decreases when I let off the gas pedal, have replaced voltage regulator but that didn't change anything... any idea?
Unsure
