1965 FJ45 vent window question
avicenna110
Sunnyvale, CA
I bought the car with the vent window broken, but the PO had a pair in the box. Since it opens I thought it was the bug catcher style so I bought the weatherstrip after looking up the part number from Toyota. The weatherstrip seems to fit, but the window looks big. Are there different size vent/bug-catcher windows for different years?
Here is the window that I got, the old frame I took out from the door is on top of it, and is smaller
The weatherstrip from CruiserParts
Vent sitting on the door:
The weatherstrip I used
Any help appreciated. Thanks
cruiseroutfit
Supporting Vendor
Moderator
Utah
Website
cruiseroutfitters.com
You bought the center pivot style w/s. Apparently it kinda fits with the bugcatcher glass/frame according to your pic, I've never tried.
We do offer a Bug Catcher W/S Kit that covers both heights:
avicenna110
Sunnyvale, CA
Bugcatcher weatherstrip no longer available, only aftermarket reproduction. I think @cruiseroutfit has the correct rubber.
I looked up the part number on Toyota for a 69 and found this:
68181-60010
Cruiser part had it so I got it from there. It fits fine it seems but I don’t know since I have the wrong size window vent.
avicenna110
Sunnyvale, CA
We do offer a Bu Catcher W/S Kit to cover both heights:
Thank you, I actually saw your old post after I ordered it, otherwise I would have got it from you. I’ll give what I have a shot once I actually figure out what’s going on with the vent window
cruiseroutfit
Supporting Vendor
Moderator
Utah
Website
68181-60010
Hmmm, it doesn't look like it fits fine or would actually function as a bugcather window to me. We also sell the (incorrect) pivot gasket you used but I wouldn't recommend them on a bugcatcher application as they simply don't work. I suppose if you're just going to have a static window, they may work ok'ish.
avicenna110
Sunnyvale, CA
I think my problem right now is identifying the actual bug catcher size I need (and how to source it), I can look for the right weatherstrip once I do that. It sounds like I have the wrong weatherstrip as well🤦‍♂️. From the pictures I saw the vent is supposed to sit inside the opening, and as @whitey45 said one side of the gasket is the pivot. My opening is <16 inches tall, the bug catcher is ~17 inches.
I looked at the 25 section quickly but didn’t find info on the sizes, I’ll look more carefully tonight.
cruiseroutfit
Supporting Vendor
Moderator
Utah
Website
Check out the link I posted earlier. Our kit covers both bugcatcher heights found on 1958-1966 doors. We've got exactly what you need.
avicenna110
Sunnyvale, CA
Thanks Kurt, will order a kit. I see that you have a lot of happy customers 😊 thank you for making these parts for the community!
Since your kit comes in a roll, and my existing one is already in place, do you think I can use your kit to just replace the pivoting section in the back of the bug catcher? Saves me from doing the corners 😊
cruiseroutfit
Supporting Vendor
Moderator
Utah
Website
You totally could but the top, front and bottom material is quite different too and you may find it much easier to just do it all.
