How do you wire the wipers to the wiper switch? In one picture attached is are the wires from the motor wiring harness two blue whites, one white black, one blue black, one black. My switch has three terminals with my attempt to wire the switch (which is wrong), see photo attached. However, the switch is not labeled. I have determined that the blue black wire is attached to the + of the switch and I have continuity between this post and the other two. At each motor I have three wires, see photo, blue black, white black and blue white. In the photo of the motor, I have applied white out to the positive terminal, the middle terminal is ground and the bottom terminal is S or park.
With the configuration that I have wired, with power from the fuse box to the blue black terminal and a designated ground of the black wire...the wipers operate but will blow a fuse when the switch is turned off. I suppose, as the wiper attempts to Park it when this happens.
Help appreciated.
Ray
Help appreciated.
Ray
