How may I purchase?I have them available. PN 112-08A: $99.00
Are there still no solution for the brassbushings?
Is there a problem, or do you just want to change it to know you did?
I wheel my 64 more than most, and I have yet to wear one out.
I have oil mixed with the grease leaking from the knuckles, I was thinking the bushings were the problem
That will happen over time even with fresh bushings. It’s the nature of the beast. The spiral relief cut in the bushing will naturally let oil through (which is better than seizing)
If you never wheel your truck, then you can just glue the thing shut. OTOH, if you wheel a ball and claw as much as I do, you just get used to cleaning out the knuckles a little more often.
