Here is what I would do on the seat situation
I would use the drivers seat in post #809
Why? Newer design, locks in upright position and has dual locks for the slider. The OEM 40/45 seat only used a slider lock on one side and they only pushed up into place with a spring clip holding them upright.
That seat will also bolt right to your frame. You can either remove the slider and bolt the assembly to your lower frame or just the seat.
I have bits of that same seat at the house I can mail you if needed.. It was only a donor of a couple parts so don’t expect anything super nice. I can also mail you a care package of all the retainer screws for the backs/fabric. I had to buy 100..
It should use a 65 seat foam and fabric from SOR or others. I used the SOR foam cause it was the easy button. Probably could have built my own but why..
I would recommend raising the seat and the steering wheel up.. For legroom. But I’m almost 6ft.
For the passenger seat you can probably use a 40 bench cover from SOR and foams.. It appears it does not have the kickout for the gas tank. It has been a while since I have seen the stock swb fixed top seats. I gave mine to paul in Montana.
I would probably grab the seat in post 819, if needed you can source a lock up mechanism for the back from a pass seat off a 40 somewhere.
or I used a 40 bench passenger seat and relocated the legs to the correct spots. Sleeved inside the tubing and welded them back together. the 40 bench that locks upright will match your drivers seat.
Sorry I took so long to respond. Was a busy weekend herding cats. Wish I was in the woods chasing bambi but probably isn’t going to happen this year.
