middlecalf
- Thread starter
- #141
Anyone have a special technique for getting out theses hanger pins? (Rear fixed shackles). Beating and penetrant so far, maybe some heat next. Need a pusher tool, is there such a beast?
Torch it, let the rubber catch fire, put a steel plate under it to catch the drips so your new concrete does not get ruined. It will be a bit smokey.
After a bit the rubber will melt and you can slide out the pins. Quench with water, then remove left over rubber.
Got it, torch it. Thanks. These have to come out and the shackles have to come off the frame because the frame needs repairing in this location (actually the biz channel and doubler on the inside of the frame). So are there replacement bushings available for this rig? If so, who/where? Thanks.
Hey JP @ClemsonCruiser - happy post 4th!
I ordered some shocks based on your post above with pic from parts book. I ordered 48511-60010 FR and 48531-60050 RR. In other posts I see the 45 shock numbers as 48511-69037 FR and 48531-69059 RR. I haven’t heard any rejection from Camelback T like usual if parts I ordered are NLA. Any idea on difference or correct numbers?
Paul those are the worst I’ve ever seen out of a 45..... yikes . Keep them as badge of honor!One fixed perch pin is virtually out, the other is starting to move but still has some rubber vigilantes hanging on. I’ll burn their arsses eventually. Got the shackles off. Kind of looks like something you’d find excavating at a medieval castle. Might even be a bit more weathered than I can tolerate. Is there an OEM replacement option? I guess I could go with the sor greaseable shackles (and pins if they’re bad too).
