Last week I cleaned the throttle body and checked the valve clearances. I figured there would be several valves needing new shims, but all were within specs except the back #6 exhaust valve. It was at .015". For 185k mi., that seems amazing. This is the first time I have ever checked valves. I did this while the engine was cold. Should it have been hot?
I replaced the tb gasket, valve cover gasket, intake hose, and several vac lines. It seems to be idling and running very smooth now. I have recently replaced the front and rear crank seals, the oil pump gasket and dist. o-ring. Now it has no oil leaks!!! (for the time being)
(97 LX450)
(97 LX450)
