17" OEM GMC wheels fit on 97 FZJ80? (1 Viewer)
Summit County CO
I've found a some wheels with snow tires and can't seem to find any information regarding if these will fit. Does anyone have any experience? Thanks for your help!
What's the bolt circle?
It's a six lug bolt pattern but I'm not sure what it measures yet. Is that the only thing I need to consider for them to fit? I can measure them against the stock ones when I'm there.
The bolt pattern is correct 6x5.5 the issue will be with the hub diameter. You will have to find someone to bore out the hub for you to fit your truck. Also a good chance the offset might be an issue also.
