17" non-RW wheels on 2016 LC200 ?
Just circling back to confirm the choice of Icon Vector 5 in Titanium worked fine for my 2016 LC200 with the larger brakes. I had seen folks running these on old LC200 and some LX and was getting spooked about my 2016 but all good.
Looks good, but there should’ve never been any concern. Plenty of threads/posts confirming 17 works fine.
Do you know what the offset is on those wheels? Are they +25 like some other icons?
@psnyman
What size tires are you running? Also any suspension mods?
Just picked up those wheels and tire shopping now!
Rig looks great!
@psnyman
Rig looks great!
Hi, thanks! I'm running Toyo Open Country A/T III in 285/70/R17 with no suspension lift yet. These tires appear wider than the stock 285/60/R18 and I am getting minor rubbing on the front wheel headliner at full turn lock and will be pushing it forward it bit with a heat gun if I don't put on a replacement bumper or do a lift which should also solve the problem. Good luck.
Awesome, really appreciate the reply.
Was thinking about that same size, so good to confirm!
I’ve run toyos a lot but might switch it up this time and try something new. Hopefully will have it wrapped up this week and will post pics!
Sorry to bring up something old, but how did it work out? Did you find other rubbing issues with the 285/70 on the Icon Vector 5 at 25mm? Did pushing back the inner fender fix the rub?
Can confirm it worked for me. Running icons with that size wildpeaks.
Minor rubbing at full lock when in reverse. Pulled out the mud flaps and pushed back the liner with heat. No issues now.
