16lbs preload on Wheel Bearings?
Hiding
I got the front end put back together on the 40! I was setting the preload following all of the info everyone helped out with on the board. I was only able to get the preload on both sides down to 16lbs on the fish scale.
I am running 36 inch tires, What are your thoughts.
The factory Settings I was able to find say 12 lbs on the high end of preload, but I have also heard bumping it up some is "better" due to the larger tires.
Are you sure you are talking about preload on the wheel bearings? Much of the
discussion about larger preload with big tires refers to the kingpin bearings, not
the wheel bearings.
tighten inner nut to preload torque-spin the wheel a few times.
loosen inner nut and retighten to final torque.
install lock washer and outer nut to final torque setting. spin wheel a few times.
check preload/ if too much then loosen outer nut. spin wheel a few times and retoque.
spin wheel a few times and recheck preload. If still to high then loosen again. spin again and this time set your torque 1 or 2 pounds under recommended. try again.
usually just spinning the wheel a few times before checking the preload is all you need to do.
Sorry, Its the Wheel Bearings, Not the trunions.
I had about 4 different articles and threads, and followed them, along with the FSM instructions.
Put the adjusting nut on and snugged to spec. Displaced all of the grease. Backed off the nut completely. Re torqued, and spun the wheel in both directions, Got it to around 15-16lbs. backed the nut off to LESS than hand tight and still around 16 pounds. I was not comfortable backing the adjusting nut off so it was loose, (less than finger tight) and then installing the lock washer. So I kept it a little less than hand tight. then finished the with the star washer and lock nut. Putting on the lock nut and torquing to the upper end of the specks, I think around 70lbs. Did not make any difference on the preload. It took about 16 lbs to get it spinning and then it went pretty freely.
Does this make sense?
If both wheels are at 16lbs, is this a recipie for disaster? I have not driven it yet so its not a huge deal to pull the lock outs and such.
Thanks guys, Warren.
