I'll be buying tires soon as well, but I'm curious, what are there benefits going up to an 18" wheel?sejinro said:Are there any issues with going from 16" wheels to 18" wheels on a 2000 LC?
johnroyale said:I'll be buying tires soon as well, but I'm curious, what are there benefits going up to an 18" wheel?
18s do look good but larger brakes are even more appealing.hoser said:Bling! Well, you could also fit that 14" big brake kit
Two alloy wheel combos both with the same tire diameter and width, the 16" wheel will weigh less than the 18" wheel combo. I don't have the exact weight but I think it's more than a 6lb difference (wheels alone). However, IIRC, the OEM 16" steel wheels weigh close to if not more than the 18" alloy.
BFG AT/KO
285/75-16 55lbs
285/65-18 54lbs
