15" wheel on FZJ80?
Discussion in '80-Series Tech' started by trailcarnage, Feb 15, 2004.
  1. trailcarnage
    trailcarnage
    251
    Jan 25, 2004
    Da UP, eh...
    I am putting my rear buggy axle together today. When I went to install the rear wheels onto the axle I found that the caliper hits. DOH! It looks like a little grinding will cure the problem. I just wanted to confirm that this can be done before I waste my time.
    They are 15x8" wheels and the WMS is 3/4" off-center of the rim. Any guidence would be gladly appreciatted!
  2. Gumby
    Gumby Supamod Staff Member s-Moderator
    12,193
    649
    Dec 13, 2002
    Knee deep in hookers and gin
    They might fit with some grinding. There have been a few folks on this board that have done it. MrBryan has, for sure.
  3. cruiserdan
    cruiserdan SupportingVendor Emeritus Moderator
    22,323
    6,633
    Mar 27, 2003
    Land Cruiser Heritage Museum broom closet
    You would need to grind on the rear calipers for certain........
    Before you do so, I would recommend you get in touch with Christo BEFORE you start. He will have some insight.
    If you get carried away and grind off a bit too much............ :whoops: I know where you can get new calipers.... :rolleyes:
  4. trailcarnage
    trailcarnage
    251
    Jan 25, 2004
    Da UP, eh...
    [quote author=cruiserdan link=board=2;threadid=11551;start=msg105276#msg105276 date=1076883457]
    [/quote}
    Get carried away? Who me? Never... :D
    I will try that. I hope he has a chance to respond promptly. I proceeded to weld on my beadlocks. Now I am pretty much commited. Or mzybe I should be? ???[/quote]
  5. Mr.Bryan
    Mr.Bryan
    1,199
    72
    Mar 28, 2003
    Over here
    Yea, I done dooed it. Grinding them down isnt too hard a thing, just be very cautious. Keep a wheel there so you can take a little off, and check to make sure it fits. Once it does, stop. My only uncertainly about having smaller wheels on the vehicle is heat dissapation. I only use the 15" wheels for wheeling. I dont use them for daily driving so if your in alot of stop and go traffic, it may be bad for the brakes. But, yea, if its for just offroad, then its all good. Oh for referance, I took off about 1/4 inch from the top of the caliper. I've not had any reprocutions from this and I did it about 9 mo. ago.
    Good luck
    -Bryan
  6. Junk
    Junk
    6,177
    29
    Dec 13, 2002
    buggerville nj
    Trailcarnage,
    I talked to Christo about this and decided against it. At this point, I may be moving to 17" rims, but would definitely grind just to fit 15's on. Why do you need 15"?
  7. trailcarnage
    trailcarnage
    251
    Jan 25, 2004
    Da UP, eh...
    [quote author=Junk link=board=2;threadid=11551;start=msg105435#msg105435 date=1076899986]
    Trailcarnage,
    [/quote]
    Junk,
    The reason that I am going to run 15's is for the tire selction. As I stated before, this is a competition buggy. I will see minimal on-road usage. I am just trying to be sure that it will be safe on the trail.
    I checked out the area that I will have to grind thoroughly. This area is very significant to the strength of the caliper structure, but I thinl for a 5 MPH or less vehicle it will be safe. I will stiil have more cross-section on the rear caliper than a Samuari. Not to mention that the rear brakes wlll be taking minimal loads.As we all know that is the nature or rear brakes. What does it run? 60/40 or 70/30?
  8. Junk
    Junk
    6,177
    29
    Dec 13, 2002
    buggerville nj
    I've heard some quote the ratio as 70/30 (F/R) or as 80/20. Is this truly a buggy (went to your site to see and couldn't find pics) or an 80 that's been buggified? Reason I ask is the weight. The weight on an 80, on grinded down calipers, in a comp type trail could be tough on it. If it's a buggy, weighing in at 3,800 lbs or so, then it may not be that significant.
    Also if it's an 80 that's been buggified, are you sure you want 15" tires? You could get a lot of roll with that versus like 17".
    Just asking so we can give you a better answer.
  9. trailcarnage
    trailcarnage
    251
    Jan 25, 2004
    Da UP, eh...
  10. inacoma
    inacoma
    509
    2
    May 16, 2003
    Aurora, CO
    I ground on my rear calipers, ran 15" rims...worked well...looked stupid (now I have stock 16" with 35" trxus :))
    but looks are not what you are interested in. it works, doesn't take much grinding...my truck still stops :)
    Kumar
  11. bjowett
    bjowett
    3,680
    1,383
    Oct 28, 2002
    Western Massachusetts
    I have clearanced a few calipers over the years on various vehicles, never had a problem.
    One thing to consider pertaining to to wheel diameter, is that larger wheels have more bead to hold a tire. This is one of the reasons I lean towards larger wheels these days. A 15" has approx. 47" of bead contact, 16" has 50" and a 17" has about 53". :cheers:
  12. trailcarnage
    trailcarnage
    251
    Jan 25, 2004
    Da UP, eh...
    Kumar-Thanks for the confirmation. That is on my to-do list for tonight.
    bjowett-I appreciate what you are saying about the surface area but I already have a set of beadlock wheel. They have about 34 suare inches of sealing surface. Jumping up in size also limits my tire selection not to mention that the 15" wheel will allow for more tire flex.
  13. bjowett
    bjowett
    3,680
    1,383
    Oct 28, 2002
    Yeah, beadlocks make it a moot point.... plus bigger wheels = $$$
    Good luck with it!
