I think post #20 answers your question. CheersCool, what is your suggestion for the OP?
edit, it sounds as though in the first post his travel contradicts your comment on 14" un-needed.
Word. I may have to do some flex testing without shocks installed to see how much my shocks are holding me back in “real world” scenarios. I’ll look threw the shock & suspension tech again.The only time your axle will drop out fully is when you jump the rig completely off the ground. That’s why I said “ in real world, on trail scenarios.
I run Dobinson 3.5” taper coils with 1” spacer on to totaling almost 5” lift and what’s referred to as a 6” lift shock made by Ironman (a 12” shock). My Delta arms do allow more articulation than wider stock arms but still don’t max out the springs even in the worst rock crawling situations. The radius arms simply won’t allow it.
This is nothing new and has been studied and discussed in depth here.
Lots of reading here and more to be searched out:
Compiled 80 series suspension component spec thread... shocks, coils & more.
80 series coil & shock specs A few years back 80 series suspension was fairly easy to figure out & purchase since there was only a few of options to chose from. Recently there has been a few suppliers stepping up to play in the USA 80 series market offering more options. Now with a plethora of...forum.ih8mud.com
I had the 80 on the lift. Unbolted the shock & measured, that is the measurement in witch the shock was 4” short. Granted, like you said, this condition would only occur when “jumping” the truck. Then I bolted the shock back on & flexed it in the washout behind my house. It found the limitations of the 10” shock quick in a real world situation. The reason I considered a 14” shock with a custom tower was because from the measurements I have looked at on 12” shocks, I’d be getting darn close to not having enough up travel without topping out the 12” shock. A 12” may be enough if placed perfectly. But I know for sure a 14” would give me a little lead way up & down so that I did not ever top, or bottom my shock out. Like I said. I’ll try out a 12. But it may require a shock tower mod to get it in the sweet spot. I just don’t know yet. I am not trying to discredit anyone’s proven formulas. I’m just trying to maximize my combination given my springs & radius arms.You mention "when you let the suspension droop", what was the situation for which you did that? If it's something that isn't likely to happen in real world conditions then maybe reconsider, but if you want to capitalize on as much capacity for travel and consider improving your link setup in the future then it might be worth while in the interim.
If you feel you may go to more or less lift at a later date in the plan, then I'd want to build with that in consideration, i.e. moving axle forwards, axle travel with larger tires etc.
Would there be any negative to running a 12" shock in this situation?Something else to consider is that even though our Delta arms are thinner and will allow the arm to twist more degrees, we still run the same rubber bushings which don’t like that. My bushings have two years on them and are showing signs of degradation already due to the rock crawling. After market bushings live even shorter lives.
12” shocks and for sure 14” shocks are in 3 link territory.
That Chevy crew cab is sweet. I had a 78 Ramcharger for 15 years in between LandCruisers. It was a DD that evolved into a trailer queen. I decided to tone it down and get a more versatile vehicle so came the first 80 in early 2014. I’m on my third 80 now. Rolled the second one and have built this third one way beyond what I ever intended and I’m well into Grandpa years. I think that erge to cut and modify is in a persons blood and never goes away. So good luck keeping you 80 stockish. Triple lockers, 4-5” of lift on “good” springs, armor and 37’s will do amazing things off road even on radius arms and then cruise home like nothing ever happened.But, that being said. I imagine after either a turbo kit or LS swap I’ll eventually get to the point where it’s going to need links…. I’m hoping someday I’ll get over the urge to cut everything I own into a million pieces & “build” it.
