yall, I'm racking my brain trying to figure out why this truck is idling rough (missing/stumbling), but only when it's nice and warmed up (10 miles on the highway or 30 minutes driving around town, 300+ egt at idle). Before it gets completely warmed up, it runs like a dream. It also runs fine in neutral, and even if it's allowed to roll forward in gear. But warmed up, with your foot on the break in drive, it consistently runs like it's missing a cylinder.
I've had the fuel-system pressurized, there are no leaks between the tank and lift-pump. I've been through the pump banjo-bolts, lines and return lines looking for leaks, and had a mechanic take a look as well. Given the fact that it runs fine cold, coupled with all the unsuccessful searching I've done to find air, I don't think I have air in the lines.
If it was an IP or injector problem I feel like it would also present while cold. The IP was supposedly resealed and injectors were supposedly rebuilt from the mechanic I bought the engine from, but I'm not 100% sure any of that really happened.
I've been reading everything I can get my hands on, and I'm beginning to think I may have a boarder-line timing problem (the engine manual identifies this as a possibility for the problem of rough idle when warm) or possibly something going on with the valves (it's direct-injection and we do a lot of in-town driving)? I've read that you can be just barely in spec, but then when the engine warms and the oil thins out, tolerances can loosen and push the timing over the edge out of spec (though this is more a problem with engines that have timing chains, which can stretch (the 13bt has a timing gear))
thoughts?
If you were me, what tests would you try to run first?
thoughts?
