13B-T tuning
I have an '88 BJ-74 with 13B-T. I live in Albuquerque, New Mexico at 5,000 ft. My cruiser was obviously from sea level. It blows copious amounts of black smoke when accelerating, or starting in cold weather. I frequently drive as high as 10,000'. The higher I go the worse it gets. So, can I get smaller injectors, or, increase turbo boost, or reduce fuel pump pressure to lean out my fuel/air mixture? Or, are there any other ideas that I didn't think of to fix this problem?
Thanks,
Rob
I should start with the simple and less expensive things ..
1. Air filter ?
2. Fuel filter .. ?
3. Add more boost ( boost controler - bleeder for your CT26 ) and check if that reduce the black smoke.
4. Buy a Pyro Guage
5. Finaly get the injectors services ( here are very cheap like 25 USD per injector .. )
let us know ..
P.S. maybe your HAC isin't finction well ..
How does one turn up the boost?
Search= Boost Controler
Boost Controler = device that will " lie " to your factory wastegate and alow your turbo make more pressure after the wastegate blleeds it ..
