And you have a "real" wastegate controller, and not one of those goofy-assed grainger check valves?
Its a little known mod called a throttle pedal. Seriously, you are on a path that will only end up at a rebuilders shop. Diddling with the fuel without an EGT gauge is the quickest and most surefire way to get a fresh engine, via a rebuild.I was thinking, if fuel is set high yet boost is at stock levels do we still get higher EGTs?
Is there any way I can adjust fuel from inside the cockpit? Has anyone ever come up with any such mod?
