13 gallon factory tank in a '73 FJ40?
Oceanside, CA (Fire Mountain)
I searched EVERYWHERE for a recent thread on factory fuel tank capacities w/o luck. Can I really be this stupid? Anyway I can't recall the actual capacities being argued, but it seemed odd the capacities being tossed around. Did some 40's come with a 13 (or close) gallon tank? I can fill it until I see fuel in the neck (13 gallons) and the gauge works fine. I can run it dry and still on fill-up... 13 gallons. Anyone? Pimp?
Thanks
-Dom
stock was 16 gallons, then it went to 22 gallons in 79 or 81.....I forget
Not sure why I would only get 13 gallons with a dry tank and fuel showing at the fill tube. I replaced my old original tank (13 gallons too) with a Toyota Factory replacement. Anyone have an idea of what the hell is going on? Pimp do you have a '73 owners manual with specifications page?
73 US broucure shows 18 gals, 75 shows 16.......odd
nothing in the OM
There is probably 4 kilos of Cocaine in your tank, that would acount for the diminished capacity of petrol.
1973 Owners Manual
My 6/73 is the 18 Gal tank. I had the tank out not too long ago.
I knew it was there.............I just missed it, I have the same OM..........eyes just blury :)
Ground Up said:
1973 Owners Manual
My guage must be off. I've been filling up with 13 gallons for the last 3 years and was recently heard that it was a 16 gallon tank. So sure enough I ran it dry (had a 2 gallon can with me) and filled up with 16.3 gallons. I feel like a dumbass.
And I was only thinking dead animal parts. :D
Back Ground check on the PO might be in order. After all Baja Mex. Is a nice drive South from San Diego! (Made that run a few times… but for surfing!)
1 Gallon = 231 cubic inches So a five gallon difference is 1155 cubic inches sucking up space. There would have to be something quite large in the tank to do this. (Like a 5.25”x 21”x 10.5” block inside the tank) I would pull the tank and take a good look at it. The PO may have had a leak “fixed” in the past by cooking out the tank and having a section sealed off. Only thing I can think off as to why it would be different. Unless its not an OE tank. Photo of it?
Mark
I replaced the old original tank with a Toyota Factory replacement so it must be 18 gallons. Not sure whats going on but I'm going to run it dry tomorrow and then fill up. I'm sure I had done this but I guess I am wrong. Thanks for all the input. I sold my old tank to RockCod so I'll have to ask him to check for the brick of coke...
I know that when I was on walk with my '69, that it will take 17 gallons...
Same with my '72-40.
I now have a 16 gallon tank in the red truck, and when it is on walk, it will take 15...
Good luck!
-Steve
