HI,
Anyone swapped a 12ht into a 2H hj60 cruiser can help me out.
Got the 12ht into the hj60 today and started bolting everything back on.
Ran into a couple problems.
What do I do with the diesel return line. 12 ht runs it right back into the fuel tank. the hj60/2h runs it back into a valve in the top of the injector pump then back into the inlet of the injector pump at the bottom.
Do I need to run a new line all the way back to the tank?
There are a few extra plugs in the loom of the hj60 . can I just leave them hanging, or shall I take the whole loom out of the 12ht cruiser and wire it into the hj60?
How do I sort out the pre heat on the 12ht, what do I need to swap over?
Also the small fitting that is bolted onto the inlet crossover pipe which has vacuum lines running to it also has 2 wires and a plug , where do these wires come from?
Anything else that I need to know ?
any help much appreciated.
