Gents,
Looking for some input on the most logical place to start diagnosing this issue. The other day while driving my truck home, it started to sputter, choke and lose power to the point I had to pull over. I kept it running, but the idle was choppy and when I feathered the throttle it acted like it was running out of fuel.
I managed to keep it going and limped back home, fortunately I was less than a mile away. The next morning, I went out and fired it up and it started as it always has and ran perfect. I drove it a few miles and all seemed well. Later in the day I decided to venture out a little further and as soon as I got on the freeway and got the truck up to operating temp (165 F), same crap with the sputtering, and then she died.
I was able to limp home by letting it cool a bit, starting...driving a few hundred yards, then it would die again....let it cool a few minutes, repeat...etc etc.
I started it again this morning, and it runs like a champ. SO...obviously whatever is causing this is only present at full operating temps.
ENGINE HISTORY
135k miles on well looked after motor from a Canadian JDM donor HJ61
Conversion was done on US spec FJ62 / sits behind an H41 tranny / Toybox combo
All perifs were new or rebuilt when motor was installed (alt, cooling system, gaskets, seals, injectors etc)
Truck has run flawlessly for 2 years, never let me done when far from home
RECENT WORK
I have a LRA 38 gallon tank that my fab guy recently did some surgery on...basically shaved the tank for a better departure angle. My first thought was perhaps there was some contamination particles that were introduced during that work...but if that was the case, it would run like s*** when cold too.
POSSIBLE CAUSES
Anything to do with fuel delivery makes no sense since it runs great when cold...so things like blockage at the pickup, fuel pickup and return lines accidentally hooked up wrong when tank was reinstalled, fuel filter blockage, feed pump....all these make no sense to me...right??
So knowing this is an intermittent issue that only seems present when engine is warm is making me think things like, bad VSV, air intake butterfly valve, automatic timer, or some other way air is getting either choked off to the intake or air being introduced into the fuel system that makes it run like s***, then die.
Another thing I noticed yesterday...I used to be running about 10 lbs turbo boost and now I'm only seeing about 8lbs. This IS the original turbo, nothing has been done to it by me, nor the PO of the engine. Same thing with the IP.
Truck has plenty of fuel in the tank
I'm in California, so climate is not a factor (it's 70 F today)
So...that all stated, has anyone experienced anything like this with a 12HT??
ENGINE HISTORY
RECENT WORK
POSSIBLE CAUSES
