Occasionally my 12HT will stall when I disengage the clutch as I come to a stop. The problem seems to only arise when the engine is below regular operating temperature.
My idle is set to 650, which is the factory default, but when I watch the RPM as I disengage the clutch, it actually drops below the 650 point to the 300-400 range. If the engine manages to recover, it jumps back up to 650. Any thoughts? Should I be upping my idle RPM or is there something else I should be looking at?
Thanks.
Thanks.
