12HT and A440 Lugging/Vibration in Overdrive Help Needed
Santa Barbara, CA
Website
madeherefilms.com
Ok so I've been wracking my brain about how to fix this but my HJ61 has this very specific low frequency "womp womp womp" lugging vibration sound and feeling as soon as the truck shifts into OD and only on throttle. I measured my flange angles, removed the driveshaft and drove it in FWD and it still did it (albeit less than normal). This feels more like it's shifting into OD and the revs drop down to like 1300ish and the vibration speeds up and goes away as I go faster but it feels like it has very little power right at that shift point and that's what is causing it more than like a driveshaft or u-joint issue (but since I have the driveshaft out I do plan on taking it in to get checked and potentially get a CV put in on the TC output side).
If I drive in 3 it doesn't do it at all or if I shift out of D into 3 it goes away so it's really looking like some sort of lockup/clutch material issue. I've put in anti-shudder fluid, checked my engine and TC isolators/mounts and they're all good so I'm wondering if I should try and adjust the kickdown cable or something? Has anyone else experienced this? My end goal with the truck is to do an H55 swap but that isn't in the cards in the immediate future so any help or guidance would be greatly appreciated.
What size tire and and diff ratio do you have? have you adjusted your transmission cable? 1300 does sound a little low. what speed is that 4th shift happening at? its too bad the governor on this trans is not easy to take out and tune.
I’d have to check on the feet ratio I can’t remember off the top of my head but I’ve got 35” BFG’s. I noticed it even with the stock tires but not as bad obviously.
