There appear to be 2 VSV's. One on top of the engine which is already plumbed and one on the passenger side inner fender. I'm assuming it's the fender mounted VSV I need to plumb but what goes where? I've got 2 hoses coming from the engine. One comes from a white plastic valve on top of the engine, the other comes from down by the injection pump. I've also got 2 A/C hoses coming from the engine that are supposed to plumb into the idle up solenoid (where the heck is that?) and one vacuum hose coming from the firewall. So I've got 5 hoses in total and 2 ports on my VSV. Help!! Oh yeah my oil pressure gauge isn't working either. On the 2H there are 2 pickups on the right rear engine block, the 12H-T only has one. Is that an issue?
On the plus side my truck runs like a dream with the 12H-T in it! I actually passed a truck on the highway while in 5th gear!!
Hey Sheldon,
Yes I did pull the engine and I do have A/C. The fender mounted VSV was originally hooked up:
From firewall to a tee connection then to VSV
From tee connection at VSV to A/C
From VSV to dash pot near fuel intake
On the 12H-T there were 2 unhooked lines. The white plastic valve on top of the engine and anther line coming from beside the injection block. Where do these go?
Are vacuum leaks on a diesel as potentially harmful as they are on a gasser?
Thanks
