Hello,
I've been wrestling with my 12h-t not starting for about a week. I believe I have air in the lines after sending the injectors to be serviced. I just replaced the primer pump with a bosch because the original was leaking quite a bit and bled the filter, and I've so far bled 5 of 6 injector lines at the injector.
I have puffs of smoke from the tail pipe when I crank it over.
Before I pull the crossover lines and heater pipes all apart again, I thought I would at least type things out partly as a sanity check, and hope someone might have some insight.
I had also pulled the alternator, nothing needs to be done to re-establish vacuum that I can find in the service manual?
I also adjusted the valves, without the alternator, a/c (non existent) or steering belts on. Timing should remain correct as it is all on the gears inside?
I noticed the actuator for the intake isn't moving at all when I try to start it, I assume it doesnt actually need to move until shut down as open seemed to be the default position when i had it all apart.
Is there a way to bleed or attempt to bleed the injection pump itself?
Thanks!
Thanks!
