Hey,
I have been reading numerous posts about 24-12 converters vs splitting. A friend of mine who recieved his electrical engineering from Purdue and myself were discussing this very subject. His opinion/theory was as follows, if you have a system with a 24v battery a converter is obviously necessary. He then follows up with the opinion that if 2 12v batteries are installed tapping 12v from the first battery is easiest and most effective, since the common ground is available and would simplify the wiring process. Followed by the tapping of 12v from the second battery using dedicated positive and negative wiring. He then said that the draw through either battery would powered by the alternator during running periods. The major concern would be when not running and drawing one battery down and not having enough electricity to start the vehicle. As far as wearing one battery more than the other, his opinion was, variations in manufacturing would be more valid when trying to anticipate battery life, he then said "just swap batteries once a year, that would solve that problem, real or imagined"
I must say that my 24v, military truck shows no reduced battery life, I tap 12v from the first battery to power the camper section and I swap batterys every year, I get about 7 years to a battery set, I am on my 3rd set, I have had the truck since the early 90's. I even use a 110v inverter in the camper section, and we all know how much the current draw is in those things(mine 10+ amps).
Fire away
eric
Fire away
eric
