11B or 13B injectors into a 13B-T
Discussion in 'Diesel Tech / 24 volts' started by 2 Bees, Feb 24, 2007.
  1. 2 Bees
    2 Bees
    245
    6
    Feb 26, 2006
    Black Rock Desert, Western Nevada, USA
    Hey you diesels-heads,
    I was informed by a Diesel-Head that the 11B or 13B injectors can be rebuilt with the 13B-T kit for use in a 13B-T. Is this correct?
    I just want a spare set of 13B-T injectors for back-up
    Thanks
  2. xtremitys
    xtremitys
    299
    Nov 17, 2006
    just moved to cairns , Qld
    "Hey you diesels-heads,
    Thanks"
    Is it the B and 3B injectors you are talking about and itd for a 13BT ?
    Well the 3B and 13BT are different diesel designs , the 13BT has a dish in the top of the piston where the diesel is injected into & ingnited by the hot piston dish walls as its coming to TDC , where the 3B is squirted into a pre-combustion or swirl chamber in the head and partially ignites in the chamber ,then blows thru into the main cylinder igniting most of the rest,
    i think they will have different spray patterns & different pressures of injection . you'd have to speak to a specialist diesel injection shop before you hand your money over for the kits , better to be safe than sorry . Just an Opinion
  3. 2 Bees
    2 Bees
    245
    6
    Feb 26, 2006
    Nope. Not the indirect injection B, 2B or 3B.
    The one's I'm talking about are 11B, 13B and 13B-T they are all direct injection.
    He informed me to use the 11B or 13B injector body and install the 13B-T rebuild kit for a 13B-T injector.
  4. roscoFJ73
    roscoFJ73
    14,781
    Media:
    3
    Albums:
    1
    1,278
    Jul 22, 2003
    Perth Western Australia
    The 11B/13B are usually found on Toyota Dyna trucks. Its a good bet they will interchange with the right injector nozzle kit but you need to cross reference the part numbers.These are 11B injectors from ebay ,maybe;)
    [​IMG]
  5. 2 Bees
    2 Bees
    245
    6
    Feb 26, 2006
    Yep. Those are the ones.
  6. xtremitys
    xtremitys
    299
    Nov 17, 2006
    you can get new ones pretty cheap , seen them for around 150 -200 bucks a set.
  7. rutbeer
    rutbeer
    1,742
    4
    Jun 30, 2004
    Denver, CO
    Where? Toyota has delisted the injectors as new. You have to buy the rebuild kit as far as I know....unless you have a source in NZ for rebuilts.
